93' Dakota Build
For an unknown transmission, I'd:
Drop the valve body and flush it all out
Install a Trans-go or similar shift kit
Inspect or replace the servos
Test the OD and lockup solenoids while VB is off
Install new Filter
Fill with new fluid
Adjust the bands per the Factory Service Manual
Adjust the Throttle cable/kickdown linkage per the Factory Service Manual
That will eliminate most common issues...if you still have clunking or erratic behavior after that, then either the transmission pump is going out and your not building good pressure, or the clutches/frictions or other internal parts need to be serviced by someone who can rebuild a transmission.
I Apologize
Sorry everyone for not updating this thread, ive been having troubles with the engine and some other mechanical issues and thats what ive been working on for the past few weeks with what little time i had. Next week im going to be leaving for AIT and will be gone for 12 weeks, ironically im going for 91b All Wheeled Mechanic so hopefully i will learn some more things there and upon graduation, fixing my truck lol. im not giving up on this thread, i love my truck to death and want to improve it along with all of you! unfortunately its going to be a long process... haha sorry again, fellas
