Surging problems
Old Mar 30, 2007 | 02:13 PM
Haplucki's Avatar
Haplucki
Default Surging problems
I got a 2000 rango with a 4.7 engine. Heres my problem the vehicle surgeswhile driving and sometimes loses power. I will pull out from a stop sign and have no power but the engine will race. I posted in previous post about having 2 engine codes p1776 and p0734. Someone responded saying the tran is about to blow.please don't tell me that tell me it's a sensor or something cheap to fix. I could use any help on this matter.
Old Mar 30, 2007 | 03:51 PM
Chris's Avatar
Chris
Default RE: Surging problems
Check your transmission fluid level for starters.
Old Mar 30, 2007 | 06:49 PM
4wheelin's Avatar
4wheelin
Quick and easy, go to your local shop, any shop, and have the computer hooked up to a diagnostic machine before you get upset over the tranny. Could be a simple fix.
Old Mar 31, 2007 | 04:26 AM
Mean Green's Avatar
Mean Green
It could also be your torque converter...
Old Apr 2, 2007 | 07:39 PM
brown_one's Avatar
brown_one
my wife's d had similar problem. when you would slow down it would down shift but go nowhere. engine would race. come to a complete stop and put in park. put it in drive and would take off fine. thought it was a sensor but ended up having tranny rebuilt.
Old Apr 3, 2007 | 12:38 AM
Kensai's Avatar
Kensai
If you show codes and have engine light on, it may be possible your governor actuators may have gone out. Mine went out and immediately the D went to limp mode problaby to prevent further undue stress on the engine. Also, tranny do not want to upshift past 1st or 2nd gear.
Old May 25, 2007 | 02:44 PM
Haplucki's Avatar
Haplucki
The problem was a bad converter so instead if getting it fixed i tradded it in on a 2005 Trail Blazer and i must say what a smother different ride.
