t/s lift question
Old Apr 16, 2007 | 09:15 PM
thebart316's Avatar
thebart316
Default t/s lift question
I am having some problems getting started with my lift. I am not sure what size bolts to use. What size of bolt and washers are people using and where did you get them.
Old Apr 17, 2007 | 09:56 PM
BCDurango's Avatar
BCDurango
Default RE: t/s lift question
I'm not sure what you mean... you will be re-using the existing bolts holding your current shackes in place. If you look back a few pages, I left a post specifying the size and number of washers that you eill need as spacers (as well as the beltech shackle part #)
Old Apr 17, 2007 | 10:03 PM
duelsxt's Avatar
duelsxt
ORIGINAL: BCDurango
Copy that. You will need 10 9/16 washers. 1/2 will work, thats what I used. Got em at lowes $0.17 a piece
Old Apr 17, 2007 | 11:50 PM
thebart316's Avatar
thebart316
I guess what I am asking is where did find the bolts. I thought the 1/2" bolt had too much play, and I can't find a m14 long enough. The bolts that are in there now are rusty and have locking nuts so I didn't think I could reuse them. Also, if the shackles are wider I'll probably need a longer bolt anyway, won't I? I've been to several parts and hardware stores and the longest I could find was a 100mm.
Old Apr 18, 2007 | 01:19 PM
orlandozfreak's Avatar
orlandozfreak
if your gentle with the stock bolts you can reuse them, you dont need to replace them
and i used 8 washers 3 on top, 1 on bottom each side
[IMG]local://upfiles/55047/32663E20F84043A1AAE114953DF8ADF0.jpg[/IMG]
[IMG]local://upfiles/55047/1EBE1F53DD5D41F48DF3A1FA5ADD6BBC.jpg[/IMG]
Old Apr 24, 2007 | 10:24 PM
LayItLowS10's Avatar
LayItLowS10
yeah i was able to reuse the stock bolts. i used 1/2" washers, 2 on each side on the top and none for the bottom.
