engine removal
Old Apr 28, 2007 | 03:42 AM
keithra's Avatar
keithra
Default engine removal
I have a 99 durango with two melted pistons.Im going to install used engine i got for $500.00 at junk yard .I was wondering if core support has to be removed to remove engine.Itslooks alittle tight with a 5.9 under there.Thanks Keith
Old Apr 29, 2007 | 07:30 PM
hydrashocker's Avatar
hydrashocker
Default RE: engine removal
core support
I'm not quite sure what you mean. But I'm thinking you are talking about the engine mounts. You should replace the motor mounts while the engine is out. You should disconect them at the block and leave them on the mounting frame.
Old Apr 29, 2007 | 08:57 PM
keithra's Avatar
keithra
I was talking about is there room to pull engine without removing core support forradiator sum fords require unbolt cab of truck to remove engine.Also sum fords require pull frountfenders and core support to change fan belt.
