Loss of all guages
Loss of all guages
I hit a bump today and all my guages went dead and most the lights on the dash lit up. The Odo read "no bus". I searched the forums and found 3 posabilities:
Dead cell in battery
Crankshaft sensor of some sort
PCM
How do I find the cause? I go on a camping trip in like 7 days and the D is my only towing vehicle
Just in case: 99D, 360, SLT+
Thanks!!
PCM
Thanks!!
RE: Loss of all guages
All right, I had the battery tested. It's fine. The PCM and all 3 connections going into it are fine. The lights/guages act up so randomly. I am led to believe it is a lose something somewhere. If the computer was bad, I would assume it would die like others have when this all happened. But NOTHING happens mechanically. I did notice. My cruise Control works fine when the lights are on and the guages are dead. But the lights don't show up. Then when everything kicks back on, the cruise lights come on.
Is there a plug that all the dash wires come out under the dash somehwere? A guy at advance said something about a guy who's plug was lose, but hecouldn't remember if it was a Durango, or jeep.
My wife went out today and got a piece of molding for our camper. My uncle hit the camper with his tractor and pulled up the molding and bent it. So while I was at work she went and got it. 8 foot section. On the way home she hit the brakes (kinda hard she says) and the molding slid forward and rammed the dash right under the rear defrost button. The "no bus" came on, guages went dead and when she got home she turned the truck off and then it wouldn't start back up. I got home and the truck wouldn't start because a battery cable came loose, from where I had it tested last night. I apparently did a pour job putting the neg cable on... so anyway, truck started right back up. But the guages were still dead, lights on and "no bus". So she showed me where the molding rammed the dash, I smacked it a bit on the underbelly under the radio and such, and BAM!! Everything comes back on. So apparently I have a loose something there. I'm just happy My game of hot and cold seems to be getting hotter!!!
