Engine codes help
Old May 16, 2007 | 11:19 AM
Bluedodge99's Avatar
Bluedodge99
Default Engine codes help
I took My truck to autozone and they read these codes.
P0138- 02 Sensor circuit high voltage bank 1 sensor 2
P0783- 3-4 Shift malfunction
P0740- tourque converter circuit malfuction
what do these mean and what can I do???
any help would be appriciated
Old May 17, 2007 | 12:36 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Engine codes help
Ck with the dealer and find out if you still have powertrain warranty? The transmission maybe covered under the powertrain.
Old May 17, 2007 | 03:16 AM
desertracer's Avatar
desertracer
Junior Member
The P0138 code refers to the oxygen sensor that is on the driver's side after the cat.
Bank 1 means driver side, bank 2 means passenger side. Sensor 1 is before the cat, sensor 2 is after.
You probably need an oxygen sensor...
Old Jun 7, 2007 | 07:32 AM
kent_08's Avatar
kent_08
agree with the above posts. it seems that you have to replace your dodge oxygen sensor with a new one. A friend of mine had been in the same situation before, replacing the 02 sensor solved his problem
