BUMPS
Old May 17, 2007 | 12:55 PM
mtgrady1's Avatar
mtgrady1
Default BUMPS
BEEN HAVING PROBLEMS WITH THE FRONT END OF MY DURANGO PULLING TO THE SIDE WHEN I HIT A BUMP IN THE ROAD GOING AT HIGH SPEEDS. JUST WONDERING WHAT IS CAUSING THIS AND WHAT I COULD DO TO POSSIBLY FIX IT.
THANKS
Old May 17, 2007 | 02:30 PM
cirazno415's Avatar
cirazno415
Default RE: BUMPS
Mines did that before on highway potholes at 65 plus...a little scary if you don't expect them. My cousin told me it was a flaw of the power steering, but, when I changed my shocks it had stopped doing that oversteering thing over the highspeed bumps. I have blistiens shocks. You also might want to get an alignment done.
Old May 17, 2007 | 11:35 PM
PJ2's Avatar
PJ2
Default RE: BUMPS
Lift the truck by the frame so the front wheels spin freely. Then pull out to the side on the lower part of each tire 6 o'clock and the same at 12 o'clock.There should be no play. If the tires moves of axis and has play you need ball joints. Then push and pull for the 9 o'clock and 3 o'clock postion to see if there is play in the steering assembly.Kind of the shade tree approach but it can tell you a lot. Check to make sure you D had the ball joints done under recall!
