Slow starting engine
Old Sep 18, 2004 | 05:54 PM
Salvador's Avatar
Salvador
Default Slow starting engine
Hi, I've recently bought a 1998 4x4 Durango SLT with a 5.2 engine and 70k miles on it. Every time I try to start the engine it seems there is no gas on the inyectors, I have to keep on starting for about 4 seconds, then it works normally.
Someone told me the problem could be a check valve near the gasoline pump. This valve have to mantain pressurized the gas lines and when it fails, the gas returns to the tank so when you try to start again the engine, the gas lines have to fill again.
Please help me this problem
Salvador
MEXICO
Old Sep 19, 2004 | 02:49 AM
dodgemech's Avatar
dodgemech
Default RE: Slow starting engine
Replace the fuel pump pressure regulator, it is the silver peice the fuel line connects to on top of the fuel tank. Yes, you will have to lower the tank to get to it.
Old Sep 19, 2004 | 02:52 AM
mastertech's Avatar
mastertech
yes do that first and if that doesnt work replace the complete fuel pump assembly
Old Sep 19, 2004 | 03:03 AM
chrisandclauida2's Avatar
chrisandclauida2
i dont understand why people throw parts at their car hoping to fix the problem. pull the codes .you may have to do it right after the start. if no codes then start with a fuel pressure gage and check the pressure on the rail. if therail dosent have fuel in it then you can go on to check the other componets in the system. check for cmall leaks then the regulator.any good service manual will list the componets their location and how to test them. you can get the whole dealer service manuel from different sites like e-bay in pdf format for 10 bucks or so.
Old Sep 19, 2004 | 03:11 AM
mastertech's Avatar
mastertech
either that or take it from someone thats ran into this problem 8000 times
Old Sep 24, 2004 | 12:08 PM
Salvador's Avatar
Salvador
Thanks for your comments. I will start pulling the codes then will go for the rail and pump. Hope to solve this problem soon.
