5.2 to 5.9 Engine Swap
Old Jun 6, 2007 | 02:19 AM
orlandozfreak's Avatar
orlandozfreak
Default RE: 5.2 to 5.9 Engine Swap
for $250 he can get a custom ECU im still not seeing a problem.......he obvisously knows what hes doing so i'm sure he alraedy knows his option as far as ECU reprograming/custom setups will run
Old Jun 6, 2007 | 02:48 AM
Lil Red Mopar's Avatar
Lil Red Mopar
or, what about an ECU from the junkyard, I helped a friend do this swapping a 305 for a 350 in a '90Camaro it worked no problem.
Old Jun 6, 2007 | 06:17 AM
Mean Green's Avatar
Mean Green
Mileage has to be flashed into the PCM. We had another guy on here that did the same thing and he had nothing but problems...
Old Jun 6, 2007 | 02:29 PM
Durango911's Avatar
Durango911
I'm having hughes engines reprogram the computer and I already have one for a 5.9 durango.($439) I honestly can't see this being that difficult of a project.(unless I put the turbo back on it)
"I'll buy your motorless Durango for $1000 when your done"
KEEP DREAMING!
Old Jun 10, 2007 | 12:58 PM
scustoms's Avatar
scustoms
We just completed this swap and are having an issue with the horn squealing when you push the gas.....??? What would cause this? We have great oil pressure, water temp etc. Haven't been able to get it on the road to check it out due to the horn issue. And it squeals not honk....even when you honk the horn it squeals.
Old Jun 10, 2007 | 01:14 PM
Last Of The R/Ts's Avatar
Last Of The R/Ts
ORIGINAL: scustoms
LOL man, I know this isnt a funny issue but I could just imagine someone sitting at a light and when they go to take off, SQUUUEEEAAAL! I would have to agree with everyone else on this topic, buy a D with a 5.9, they are out there by the truckloads and cheap. At least it will save you headaches galore.
Old Jun 10, 2007 | 01:54 PM
scustoms's Avatar
scustoms
Not to be rude...but buying another truck isn't an option I would even think about. This has been a GREAT truck, 150K+ milesand this is our first issue. Granted its a big one but not compared to having a car payment again and the other horror stories we have heard. (Not to mention its the wifes truck and sheloves it.) The new engine is boughtand now in the truckand so far its been easy going andMUCH cheaper then having someone else do it for you. We have all the tools we probably would need but the computer to read the codes /Flash the computer.
Old Jun 10, 2007 | 11:41 PM
Durango911's Avatar
Durango911
I've never heard of anyone having that problem. I honestly don't even know how it's possible. I'm just now starting to do the swap. I'm ordering a short block at the end of this month.(don't have time/$$ to build one) If you have any pointers on the swap, it's always appreciated!
