Viper Fan upgrade....worth it?
Old Jun 20, 2007 | 08:43 PM
  #31
Mean Green's Avatar
Mean Green
Default RE: Viper Fan upgrade....worth it?
https://dodgeforum.com/m_817322/tm.htm
This was in the Dak section, just look for rtkota5point9's posts. He has a digram up as well and apparently the fan is always on.
Old Jun 20, 2007 | 08:46 PM
  #32
cesspool's Avatar
cesspool
I saw that thread. It's a dandy!!!
I saw on ebay that a 98 and newer Mark VIII fan pulls more CFM than the older ones. Any truth to this? Could just be a ploy, but you never know....
Old Jun 21, 2007 | 12:13 AM
  #33
Mean Green's Avatar
Mean Green
I dunno but I Just got everything I need to the tune of $100.00
Old Jun 21, 2007 | 03:54 AM
  #34
IndyDurango's Avatar
IndyDurango
Look what I started! [8D]
So Green, how did you like the clearance and the install? Where are your pictures! LOL
Here are a few helpful links:
http://www.dakota-durango.com/forum/...ad.php?t=33039
http://www.dakota-durango.com/forum/...ad.php?t=28673
http://www.dakota-durango.com/forum/...ad.php?t=32414
IndyD
Old Jun 21, 2007 | 04:21 AM
  #35
Frenchy's Avatar
Frenchy
I got mine hooked up, using rtkota5point9's method, and yes, it's always on, I let it run sometimes after my truck is off to cool the engine...
total cost for me....
20 for the fan..
6 dollars for the two relays
5 dollars for 45 feet of 10AWG wire
31 dollars.. and averaging about 22.3mpg on the highway... up from 21.1 before e-fan...
4.7L 4WD.
Old Jun 21, 2007 | 05:23 AM
  #36
Mean Green's Avatar
Mean Green
Well I went around to a couple auto part stores and got the stuff I needed (a little too much I'm gonna have to go back and get a refund[&:]). The relay I got had all the wiring done already and hadvery good instructions on how to wire the fan up properly and have the a/c kick the high speed on for me, while the low speed is kicked on by the engine temperature through a radiator temp probe. For anyone that is interested and good at wiring here's their instructions. I can't wait until next tues. or wed. I am gonna slap this baby in.
[IMG]local://upfiles/37840/4F7F0E42506D47C3BC7E3288A8B29E48.jpg[/IMG]
Old Jun 21, 2007 | 12:44 PM
  #37
Kensai's Avatar
Kensai
Mean, if you go with the dual relay setup I would recommend to use the low speed setting for your A/C and the high speed for the temp probe. Always use the highest cfm rating when cooling is called for by your D.
Otherwise, if low speed is always on, and the temp probe is used for high speed, that should be okay.
Old Jun 21, 2007 | 01:16 PM
  #38
cesspool's Avatar
cesspool
Heres a link I found about the fan.
Here one about the CFM (4800!! at 14 volts.)
http://www.corral.net/forums/showthr...t=electric+fan
I've read on a couple site that itpulls 30 amps to run and people recommend a bigger alt. But these are also on different cars. Can our D's handle this power need stock?
Old Jun 21, 2007 | 04:15 PM
  #39
rtkota5point9's Avatar
rtkota5point9
You won't need to upgrade the alt.
Old Jun 22, 2007 | 04:25 AM
  #40
ShadowRango's Avatar
ShadowRango
I don't know why everyone is fussing over how much air the viper fan pulls in. Think about it...depending on what year they come from, it is designed to cool a 488-505 ci V10. It'll coola V8 with ease. Here's a site with viper fans for cheap: http://www.trademotion.com/partlocat...;siteid=214096
They are p/n P5007266
