Engine Coolant Sensor Location
Old Jun 20, 2007 | 01:43 PM
VydorScope's Avatar
VydorScope
Default RE: Engine Coolant Sensor Location
I read that thread, not sure that it applies. With the relay jumped, my temp is staying under 200. I do not presently tow anything, but I hope one day to be rich enough to buy something to tow [sm=smiley4.gif]
So how do I tell if the clutch is bad then?
Old Jun 20, 2007 | 01:46 PM
Mean Green's Avatar
Mean Green
If you are normally running hot when you are stopped (or in stoop and go traffic)but are fine at higher speeds I would be willing to bet your fan clutch is dead.
Old Jun 20, 2007 | 01:49 PM
VydorScope's Avatar
VydorScope
Well the electric fan never clicks on, so when sitting idle it does start to heat up. With the electric fan on, it seems fine.
Old Jun 20, 2007 | 05:31 PM
Mean Green's Avatar
Mean Green
Definitely a bad fan clutch. I'll be selling mine once I get this e-fan in I've only had it for I believe less than a month and it gets the job done very well.
Old Jun 20, 2007 | 05:32 PM
VydorScope's Avatar
VydorScope
OKay I am a bit confused... why would this be the fan clutch and not the temp switch?
Old Jun 20, 2007 | 05:39 PM
Mean Green's Avatar
Mean Green
Because if your fan clutch isn't kicking in properly then it won't have enough power to suck air through the radiator. it may spin but that doesn't mean much at all. You will know it is working when you get a good fan clutch in there trust me. I couldn't even take my D offroad with my old fan clutch I would start to overheat pretty quickly, the new one didn't let me go over 180.
Old Jun 20, 2007 | 05:42 PM
Kensai's Avatar
Kensai
As stated earlier, your oem efan is never setup from factory to supplement engine cooling. It is only designed to come on/off with your A/C system. I have never seen my Efan powers on due to excessive high engine temperatures. If your engine starts to overheat, it is because your clutch fan has gone bad. The OEM efan will not provide enough air volume to keep your 5.9 cool. Trust me, I been there done that. Thus why I and mean green and others that had their fan clutch replaced are now complaining about the fan roar. But at least we know it is doing its job moving enough air across the radiator to keep it cool.
Old Jun 20, 2007 | 05:46 PM
Kensai's Avatar
Kensai
ORIGINAL: Mean Green
So you going for the Mark III fan setup? If so, let us know how it goes and how much retrofitingit requires as it came from a ford! { I dread usingparts fromFORD} But for $45, its worth a shot! Then I want to see some real results on cooling when you really put your 5.9 under alot of load like climbing hills, towing, etc...
Plus, does anyone know what power requirements the Mark series fan needs? I am sure there are some durangos that may not have the heavy duty alternators on their trucks to be able to supply this extra power.
Old Jun 20, 2007 | 05:50 PM
VydorScope's Avatar
VydorScope
Okay... but the E-Fan never comes on, and I have the A/C on full time lately. So perhaps its both? The truck has served me for 170k miles with little to no trouble so I do not know much about how it works. It is only when something goes wrong you really start learning.
Mean... where did you get this clutch from and how much do they run? I think you said in another thread you paid $67, but I do not recall where you said you got it. With the E-Fan ruining it stays cool under normal driving/idling so far.
Thank you for the time your taking to answer my newb level questions! Love the truck and I plan to keep it till it has to be retired to the junk yard....
Old Jun 20, 2007 | 05:58 PM
Mean Green's Avatar
Mean Green
ORIGINAL: Kensai
Well Kensai it looks like I would have to either remove this fan from it's shroud and make it fit with my overflow tank or reove the overflow altogether and get a smaller overflow and washer fluid reservoir. To keep it looking stock I really hope I can just make the e-fan fit in my OEM shroud. We'll see I guess. I maygo pick up the stuff in a few minutes herepossibly do it today.
Oh and it was only 31 bucks from the junkyard I just had to pull it myself which took all of 10 minutes.
