tps and the tranny
Old Sep 28, 2004 | 01:42 AM
DodginLife's Avatar
DodginLife
Default tps and the tranny
ok need a tranny tech here...i was told that the tps somewhat tells the tranny how to act. my 2000 5.2 durango slips when up shifting and slips with hard down shifting. moderate downshifting is fine also if i accelerate a littile harder then normal it up shifts fine. and it always acts the same, had the tranny flushed and refilled (of course) and replaced the tps...also it has a crap load of miles 137k to be exact, paid 5k though...time for a new tranny or is it a sensor problem?
Old Sep 28, 2004 | 04:15 PM
Kensai's Avatar
Kensai
Default RE: tps and the tranny
I think it is more of a speed sensor rather than a tps sensor that governs the transmission. TPS usually governs how the engine idles and is part of the cruise control as well. If the speed sensor replacement does not work, you may want to check the governor and the actuator switches on the tranny. Mine went out and made my tranny go limp mode!
Old Sep 29, 2004 | 12:56 AM
DodginLife's Avatar
DodginLife
ok so then where is the speed sensor located at?...and is that the actual part name of it...dealer item?
Old Sep 29, 2004 | 02:22 AM
Kensai's Avatar
Kensai
I think you can get the speed sensor from some big nationwide parts stores. Check Autozone, I had no luck with NAPA. I think someone said the sensor ran around 2x.xx bucks. The sensor should be located near the end of the transmission problaby toward the top. You should see a electrical wiring harness attached to it.
Old Sep 29, 2004 | 05:29 AM
DodginLife's Avatar
DodginLife
when you say end...you mean driveshaft end on the top of the actual transmission housing?...thanks for the help
Old Sep 29, 2004 | 11:27 AM
Kensai's Avatar
Kensai
ORIGINAL: DodginLife
Here is a link to get a picture view of where it is.
http://www.autoclinic.net/article/chrysler/durango.htm
Old Sep 30, 2004 | 01:11 AM
DodginLife's Avatar
DodginLife
thanks man...appreciate it
