help... No longer needed!!!
Upon, wiring the fan up in my D, I lost all power to the durango. It started once, then it wouldn't start again and I lost everything. Afrter 5 mniutes I got power back, then I tried to start it, and nothing again. before I tried to turn the truck over, the fan ran fine then when I turned the key the rest of the way I lost everything again. 45 minutes or so and nothing has come back. I have no lights, clicking or anything with the exception of my brake controller flashes for some reason.
please offer up any help!!!
little update:
When I pull the IOD fuse, there is a clicking noise behind the dash. With it out the keys bell will ding tewlling me the keys are in the ignition and if I hit the hazzards they click, but no lights. Only with it out though. Related? I don't know....
No. I cut all power to the elec fan. It's almost like when the battery cable is loose when you start the truck it starts to turn oven then nothing, that happened and now I have nothing still. It kinda acts like something isn't grounded or the battery has a bad connection. But I checked the grounds I worked with and the battery. Is there a fuse that would control juice going anywhere?
I just hope I didn't hurt the PCM, I really don't need that.
Well I found the problem. Somehow, in a matter of seconds I drained the battery. An electrons guy at work said if a relay goes bad or something it can happen.
I appreciate everyone's help on this. The trip is back on!!!
