HELP!!! ABS still blinking :(
Old Aug 6, 2007 | 03:43 PM
flieder's Avatar
flieder
Default HELP!!! ABS still blinking :(
I just put a new Abs Controller (computer) into my 2002 Durango, I already replaced the Rear Speed Sensor but the ABS light still blinks and chimes away[:@] Brakes are bleeded, test drove up to 60mph, reset the system by disconnecting the battery but its still chimming and blinking away......its driving me insane Anyone have any ideas cause i'm running out of options[&o]
Old Aug 6, 2007 | 11:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: HELP!!! ABS still blinking :(
Did you ck for any blown fuse?
Old Aug 6, 2007 | 11:54 PM
flieder's Avatar
flieder
does anyone know if i need to go and have my abs module re-programmed after i installed a different one??!! if so then is there a way to do it myself???
Old Aug 7, 2007 | 09:58 AM
hydrashocker's Avatar
hydrashocker
ABS is dealer item. If you want to know the problem for sure you have to take it in to the Stealership.[:@]
Old Aug 8, 2007 | 02:06 AM
IndyDurango's Avatar
IndyDurango
+1, the dealer needs to reprogram the ABS controller. You can't cycle and purge the system yourself.
IndyDurango
