Rear Axle Seal Leaking !!
Old Aug 7, 2007 | 11:26 AM
RTSport's Avatar
RTSport
Default Rear Axle Seal Leaking !!
I've got a 2001 Sport 4.7. The rear axle at the drive shaft is leaking bad. There is (0) noise and (0) movement in the drive shaft. I stopped driving it when I noticed oil being thrown up on the rear window. I'm looking for best placeto get it repaired in RI ..... tranny shop or dealer or ??
Old Aug 7, 2007 | 08:56 PM
n8ech's Avatar
n8ech
Default RE: Rear Axle Seal Leaking !!
RTS:
Sounds like a pinion seal gone bad. If you have a good relationship with your local dealer, I am sure they can handle it. Otherwise, a good 4x4 or tranny shop can do it. If you have not changed the axle fluid recently, this will be a good chance to do that and make sure all is ok internally. If there is damage, better to catch it now as the bill gets bigger the longer you wait.
Don
