what year is better?!
Old Aug 12, 2007 | 12:33 AM
  #21
Mean Green's Avatar
Mean Green
Default RE: what year is better?!
Drive it till it gives you problems, you don't want to replace it if it doesn't warrant a rebuild
Old Aug 12, 2007 | 11:19 PM
  #22
IndyDurango's Avatar
IndyDurango
ORIGINAL: 3064datazz
when do you think is a good time to get the tranny replaced? I mean, i dont want to sound dumb, i know if the truck shifts funny, then somethings wrong, but someone also said that the band in the tranny need to be adjusted as well. So how do i know the difference when the bands need to be adjusted or its time to go with a rebuilt tranny? How long could i expect to get out of a factory stock tranny in a D?
Any trans shop can drop the pan, adjust the bands and refill for $150. I'd suggest a real MOPAR trans filter and ATF+4 on the replacement fluid. Bands are only adjusted on the 5.2s and 5.9s. 4.7s have a different trans and do not have bands to adjust. As Green stated, if the service is adequate, and the trans seems fine, there is no need to worry about it. Properly serviced, the trans are as reliable as the motors. Mine has been error proof for 178,000+ miles with 24-36k mile service intervals. (Do the diffs at the same time)
Longest life = 5.9
Newer technology = 4.7
Everyday driving = 4.7
Max torque = 5.9
Towing = 5.9
It is NOT by accident that I haven't added the 5.2l in there anywhere.
Also mentioned was the AWD setups. My D is the Full Time 4x4 (AWD started in 2001) and has FT4x4, 4x4Hi and 4x4lo.. no 2-wheeling at all. I'd not have it any other way. My D is very surefooted in all driving conditions!
HTH,
IndyDurango
