Rear speed sensor?
Old Oct 18, 2004 | 09:41 PM
vectorz's Avatar
vectorz
Default Rear speed sensor?
I went to Autozone to look for a rear speed sensor. I know that it's the one that goes on the diff, but the clerk says they have two. One for output and one for input. Which is the one I need?
Old Oct 19, 2004 | 04:18 AM
rockadaous's Avatar
rockadaous
Default RE: Rear speed sensor?
If this is the one your talking about. it's the output
Old Oct 21, 2004 | 01:51 AM
Kensai's Avatar
Kensai
Where would the input sensor be at I wonder?
Old Oct 21, 2004 | 12:22 PM
doziersdodge's Avatar
doziersdodge
Rockadaous, is the one you are showing in the pic on the diff. or on the transmission? Looks like on the transmission...
Old Oct 24, 2004 | 04:26 AM
rockadaous's Avatar
rockadaous
transmission and it's the output. hey doziersdodge is dozier your last name? rozier is mine cool
Old Oct 27, 2004 | 04:42 PM
doziersdodge
Yep, that's it.
I went to the parts store and got the output side (I already replaced the one on the diff) in hopes that it would solve my problem. (My brake and ABS light stays on). I do not have a problem with my speedometer or cruise. Just the brake and the ABS lights. I changed both and it seems that the lights don't come on as often??? I also bleed my brakes in hopes that would help too. I am lost. Any help out there on this?
Old Oct 27, 2004 | 05:28 PM
durangodude's Avatar
durangodude
If I'm having a similar prob no speedo or odo but no ABS light it's the output and thats on the tranny???
Old Nov 16, 2004 | 06:33 PM
tst31's Avatar
tst31
I just replaced my rear wheel speed sensor, the one on the rear differential, and it took care of my problem (brake and ABS lights continuously on, as well as no speedo below 25 mph). Took about 20 minutes to fix with two open end wrenches, didn't even have to lift the truck, either (I have the 4WD model, so I got a little extra clearance). However, you still have to clear the computer code with an OBD. Local shop did it for me in about 3 minutes, with no charge (dealer wanted $42.50)
Old Nov 19, 2004 | 05:12 PM
jciscott's Avatar
jciscott
tst31 Dude....
I have exactly the same deal wrong with my Durango, ABS lite, and Brake lite, no speedo below 25.
Where did you buy the sensor ???
Dealer only or parts store ??
How much ??
Old Nov 19, 2004 | 05:22 PM
tst31's Avatar
tst31
Jciscott,
Autozone and a couple of specialty auto shops said they couldn't get it, as it was dealer only. I ended up buying it at the dealer for $40.50. Kragen claimed to be able to order it, as an aftermarket part, as did Napa, for about $28, but couldn't exactly say if it was the correct part, although they were pretty sure. Just decided to get it from the dealer, since they had it in stock, and I was tired of looking around, obviously.
