2000 dodge durango power windows / locks problem
Old Aug 16, 2007 | 02:16 AM
scotmcd's Avatar
scotmcd
Default 2000 dodge durango power windows / locks problem
vehicle was in an accident with a deer and driver side front and rear door skins had to be replaced. power windows and locks worked for about a month now, however, recently all power windows and power door locks quit working. i checked the fuse for the power door locks and it is good but did not find a fuse for power windows. not sure where else to look. ideas?
Old Aug 17, 2007 | 03:15 PM
bigbaddurango's Avatar
bigbaddurango
Default RE: 2000 dodge durango power windows / locks problem
your windows have relaye its not likly its bad but i would check there under the hood did they replace the front finder?
Old Aug 17, 2007 | 08:31 PM
Kensai's Avatar
Kensai
You may want to take the panel off the driver door where all the main controls for the windows and locks are managed from. Users been reporting that sometimes the connecting wiring harness can come loose causing all windows/locks to fail. Since you had to replace the driver door, this may be a very possible problem.
