What coolant should I use?
Old Aug 17, 2007 | 12:05 AM
DDSXT's Avatar
DDSXT
Default What coolant should I use?
Is it best to use the Mopar brand or is there something I can buy at an auto part store that's just as good?
Thanks...
Old Aug 17, 2007 | 01:09 AM
Mean Green's Avatar
Mean Green
Default RE: What coolant should I use?
I have started hearing about wetter water or something along those lines and I'm hearing good things on the cooling power of it. Otherwise go with Prestone or another big name.
Old Aug 17, 2007 | 08:01 AM
n8ech's Avatar
n8ech
DD:
If you are just doing a drain and refill, I would go back with the factory stuff. However, if you are going to do a proper/complete flush and refill, you should considing going toa newer longer life coolant such as the Prestone Global G05 coolant.I just did this for my 01 on the 60k service. So far, very happy and the color of it is amber. Also, supposed to be good for the life of the vehicle. I am not sure about that point yet, but I will run it for a good while and see how it does.
Don
Old Aug 17, 2007 | 02:50 PM
scientist's Avatar
scientist
I have been using Prestone® Extended Life Antifreeze/Coolant since 30K and have never had an issue with the cooling system. I'm at 180K now and I still have original radiatior, water pump, and thermostat. I also tow and never had it reach over 220 even in standing in traffic in 90 degree weather. The schedule I keep is flush and clean the cooling system every 2 years. The mixture ratio I use is 70% coolant and 30% distilled water. Distilled water can be purchased in the grocery storeis important to use it because it has no chemicals. Do not use tap or spring water you will get corrosion over time. Oh yeah make sure you get the green extended life and not the GM dexcool one.
Old Aug 17, 2007 | 02:57 PM
bigbaddurango's Avatar
bigbaddurango
The weter water i used in my mud truckit was just a addetive. As far as The factory stuff i bet it is maid bye prestone or something anyway didnt they change the coolant to the newer stuff when did they do that? was 03
Old Aug 17, 2007 | 08:42 PM
Kensai's Avatar
Kensai
I just use the good ole Prestone antifreeze, not the realy expensive stuff. I flush my system every year regardless if it is still good or not. Easier to keep with maintenance by just schedulinga once a year changeout instead of every 2 years. That's toofar out for me to remember. Plusliving in the DFW area were we get thesometimes very cold winters andalwaysvery hot summers, Antifreeze get a good workover.
