Replacement shocks
Old Aug 20, 2007 | 02:56 PM
trbmbennett's Avatar
trbmbennett
Default Replacement shocks
Local auto shop just put on 4 monroe sensi track shocks on our 2002 durango. Should they have used the reflex shocks? Which ones are the better of the monroe brand? Thanks.
Old Aug 20, 2007 | 03:05 PM
Kensai's Avatar
Kensai
Default RE: Replacement shocks
I am using Monroe Reflexes. I think the sensatracks are a little softer on ride than the reflexes. Depends on your D and how comfortable you want your ride. Both Monroe models are lifetime warranty.
Old Aug 20, 2007 | 03:11 PM
trbmbennett
Excuse my ignorance, but is softer on ride bad? What advantage do the reflex give then? Better for off roading or something? Thanks!
Old Aug 20, 2007 | 03:45 PM
Kensai's Avatar
Kensai
ORIGINAL: trbmbennett
It's not bad, it's not good. It's what it is design for. My R/T model has a stiffer sports suspension so naturally I want a performance shock to match up. So when my R/T hits the little bumps and what not, I can feel them.
But your D may just have a regular suspension. To give more of a smooth luxurious ride. I would say if you run into some little bumps, you may not feel them as if your D just floated over the bumps.
This is the examples of softer comfortable ride or harder stiffer rides.
I would say that Reflexes are better for offroading as you would have little more control and ride handling vs the sensatracks. But reflexes are stiffer shocks so on/off roading, your D will ride stiffer vs the sensatracks.
Kinda picture the sensatracks on aLincon towncar and the reflexes on a sports car.
Old Aug 20, 2007 | 03:50 PM
trbmbennett
That makes sense. I guess since I never do any off roading, I will just stay with the sensa tracs and get the most smooth ride I can on normal driving.
Old Aug 20, 2007 | 08:38 PM
n8ech's Avatar
n8ech
trmb:
No matter what you put on your D, you are still going to feel some bumps as you might recall the 1st gen D is built from the Dakota truck platform. In my case, I too enjoy a sporty ride in my SLT, so when I ditched the oem crap at 60kI went back with Bilsteins and so far am very pleased. You will find as well that with a few hundred pounds in the back the ride will smooth out quite a bit.
Don
Old Aug 20, 2007 | 09:48 PM
trbmbennett
Yeah, I figured it was a basic truck underneath still. Well, we never take it off roading, so I guess we will just stick with the sensitac monroes.
Old Sep 1, 2007 | 08:13 PM
moparcrazy63's Avatar
moparcrazy63
Monroe Reflex shocks are better. There are supposed to provide a stiffer ride to prevent the body roll that factory 2002 Durango's have. I almost got a set of those put in my Durango, only problem was I was going out of town and wantedshocks installedbefore my trip. So, instead I opted for 4 Rancho RS5000 shocks which are supposed to be equivalent to Monroe Reflex shocks. They helped, that and since my original tires (Goodyear Eagles)had 48K original miles I got some new Firestone Destination LE's. Goodbye body roll problem. The ride is nice and stiff now!
Old Sep 1, 2007 | 08:47 PM
Mean Green's Avatar
Mean Green
Those RS5000's are the adjustable ones right?
Old Sep 1, 2007 | 08:57 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: Mean Green
nope, the RS9000's are the adjustable ones... the RSX's are self adjusting.
