New Durango Owner!
Old Sep 12, 2007 | 01:26 PM
gr8scott72's Avatar
gr8scott72
Default New Durango Owner!
Hey everyone!
I'm a new Durangoowner! I just sold my 2000 Explorer because Iwas needingsomething that can tow more than the Ex could.
I have started my own stump grinding business part time on the sideand the grinder and trailer and tools, etc weigh about 2,500 lbs, but I hope to soon have the next size bigger grinder which weighs 4,400 lbs without the trailer so something stronger than the Explorer was necessary. I ultimately want a truck but the budget won't allow for that just yet.
I work at a used car dealership (www.rvrchase.com) and we actually had the Durango here so it worked out to be almost an even swap. I ended up with a 2000 SLT with the 360 and the 3.55:1 rear end with only 85,000 basically for $5,000. It's super clean and drives great. The only thing it needs right away is a new a/c compressor.
I will be changing all fluids/filters in the next month or so as long as saving up for a different ring/pinion set (maybe 4.1:1?) along with a few other goodies.
I've been lurking on here for a couple of months and have already learned some about the D and the 360.
Hope to be around for a while and learn a bunch!
Tell me what you think of the pictures:
Old Sep 12, 2007 | 09:33 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: New Durango Owner!
welcome to the forum. sounds like you got a good deal.
Old Sep 12, 2007 | 10:34 PM
Kensai's Avatar
Kensai
You got a great deal! Not too many 2WD 5.9 owners out there. Being 2WD, I bet it can really move. Since you are going to tune it up and have all its fluids change, you may need to check to see if some of the commonly gone bad sensors have been replaced on the 2000 D. Sensors are:
Throttle Position sensor
Rear Output sensor on rear axle
Speed sensor on transmission
Judging by the pic, it looks like this D still has the factory battery. So be on the lookout for your D to have wierd engine idling/running issues if your battery is nearly depleted.
Other than that, welcome to the forums.
P.S., BTW, what is that hanging off the dash and on the center console? XM/sirrius Satelite radio?
Old Sep 13, 2007 | 08:07 AM
deerang's Avatar
deerang
Did anybody else notice just how clean the frame and sway bar are?? Wow your dealership does a good job detailing.
Old Sep 13, 2007 | 11:31 AM
gr8scott72's Avatar
gr8scott72
ORIGINAL: Kensai
I'll look into replacing those or at least checking them. Thanks.
ORIGINAL: Kensai
Battery is actually an Interstate battery so it has been replaced but I don't know how old it is.
ORIGINAL: Kensai
Thanks you!
ORIGINAL: Kensai
Yup, non-working xm that I wouldn't pay for even if it was working.
Old Sep 13, 2007 | 11:41 AM
gr8scott72's Avatar
gr8scott72
ORIGINAL: deerang
This one actually came this way straight from the auction. There are a few sellers at the auction that clean them up all the way before running them.
BUT, it's really an easy trick. All you have to do is simple green everything under there that you can get to and then pressure wash it. But that's not the trick. The trick is to then take cheap Wal-Mart rattle can paint and paint everything black. Cheap, easy and looks good. You can even take the wheels off and spray the rotorsand calipers to make them look great too.
Old Sep 13, 2007 | 03:37 PM
deerang's Avatar
deerang
Ok, I'm a bit of a nerd so I have to ask. Is your name "gr8scott72" in reference to the Back To The Future trilogy??
ahh, i thought it looked too good for a seven year old vehicle.
Old Sep 13, 2007 | 11:37 PM
gr8scott72's Avatar
gr8scott72
I've gone by that name online forever. My name is Scott and I just think it's cool
The underside of the D where it was not sprayed is still veryclean and there is no rust anywhere. No snow to have to salt here in Mississippi.
Old Sep 23, 2007 | 02:09 PM
gr8scott72's Avatar
gr8scott72
Well, I'm slowly getting everything fixed up. I've hard buffed/polished/waxed the front (hood, bumper, front fenders), replaced the plugs (autolite 3923, got to love em at $1.48 each), flushed the heater core and some of the engine coolant (very nasty looking), flushed the power steering res about 3 times now, flushed the brake res a few times also (will bleed the brakes soon), and installed a Edelbrock round 14x3 chrome intake on top of the engine. Looks great and I love the sound.
