02 durango trouble
Old Sep 15, 2007 | 03:51 PM
hostile1's Avatar
hostile1
Default 02 durango trouble
So today the turn signals and brake lights on my wifes 02 durango just quit working, one minute fine, the next no brake lights or turn signals, the turn signal indicator in the car isn't even coming on. I checked all the fuses which were fine, replaced the bulbs because they looked a little suspect any way but the lights still don't work. Anyone have a clue?[/align]
Old Sep 15, 2007 | 08:24 PM
Kensai's Avatar
Kensai
Default RE: 02 durango trouble
Did you check the flasher relay?
Old Sep 15, 2007 | 09:15 PM
Mean Green's Avatar
Mean Green
Yeah take it out and replace it, that is the most likely culprit. It is on the other side of the fuse block, you will have to get on the floorboard and reach under the dash to yank it out.
Old Sep 15, 2007 | 11:22 PM
hostile1's Avatar
hostile1
I replaced the fuse for the hazards and now I have turn signals but still no brake lights, all the fuses look good and I am no stumped.
Old Sep 16, 2007 | 01:50 AM
Mean Green's Avatar
Mean Green
Well it may just be bad taillights, there are 2 filaments and the brake light filaments may have burned out. The same thing happened to mine.
Old Sep 16, 2007 | 10:42 AM
hostile1's Avatar
hostile1
I replaced all the bulbs and still no brake lights
Old Sep 16, 2007 | 02:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
You could have a bad brake lite switch or blown fuse.
