Heat
Old Jan 12, 2004 | 02:15 PM
jenkinst's Avatar
jenkinst
Default Heat
My 98 Durango puts out almost no heat. Is this problem common? What should I check? Temp guage is good and thermostat was replaced. My D has 130k miles. </P>
Thanks</P>
Old Jan 13, 2004 | 12:15 AM
durango420's Avatar
durango420
Default Heat
Good question. My heater sucks also, it takes forever to hetat up. It was like that when I first bought it with 67000 miles on it.Mine is a 98. I would like to know if its a common problem......
Old Jan 14, 2004 | 03:56 PM
jenkinst's Avatar
jenkinst
Default Heat
Here is a snippit of a post in dodgedakota.com forum:</P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Here is the info I got from another post:
Here is an answer to the original question about the posters heater core. It is plugged. I had the same exact problem. I had flushed out my coolant system several times, but still no real heat coming from the heater. I then finally thought about it and realized the the convential way of flushing out a coolant system does not really flush out the heater core. The problem is that when you flush the coolant system out you normally connect the flushing water to the inlet side of the heater core hose and then backflush the system out through the radiator cap. This works fine for the engine and the radiator, but does not backflush the heater core. But for less than 99 cents and about 15 minutes you can easily backflush your heater core yourself. There was a suggestion on an earlier post to just reverse your inlet and outlet hose on the heater core and that would backflush it. This is true, but the gunk that is clogging up the heater core will just get flushed into you engine and will probably end up right back in your heater core. What you have to do is get a 5/8 inch female garden hose adapter. This can be purchased at just about any hardware store. Make sure it is the kind that slips inside the garden hose. Then with the engine cool you need to disconnect the outlet hose of the heater core from the engine. You need to do this at the water pump connection, which should be on the driver's side of the engine. Then insert the garden hose adapter into the end of the hose. Then disconnect the heater core inlet hose from the engine connection. On my Dakota this is easily done at the splice that is on the passengers side of the engine. This splice is where you normally connect to flush out the coolant system. Then hook a garden hose up to the outlet hose and turn on the water. Have someone help you turn on and off the water as you flush out the heater core. Try and collect atleast the first 2 gallons of stuff you flush out and dispose of this according to your local laws. After the first 2 gallons all you should get out of your heater core is dirty water. This should be ok to just dump on the ground but make sure first. You will probably have to flush the core for a good 5 minutes to fully clean it out. Then reconnect your heater hoses as they were and enjoy the heat. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o></SPAN></P>
<P class=Msonormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial"><o></o></SPAN></P>
<SPAN style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-: EN-US; mso-fareast-: EN-US; mso-bidi-: AR-SA">Check the resistor pack for the blower motor. My fan would only blow on the high setting, I replaced the resistor pack and it works fine now. The part only cost $16 Can.
On my 2001, the pack was located under the glove box in the vent plumbing. On older trucks, it might be in the engine compartment on the firewall.
Hope this helps.</SPAN></P>
Old Jan 16, 2004 | 10:20 PM
durango420's Avatar
durango420
Default Heat
sweet, Im glade you find some info..
