Durango with a battery drain
Old Sep 25, 2007 | 01:32 PM
magnumbp's Avatar
magnumbp
Default Durango with a battery drain
About once a week I go out and my Durango is dead. I am pulling 5.2 amps with everything off. So I started pulling fuses, the number 12 fuse is the culperate (interior). This fuse runs alot, my radio, interior lights ect. After a while of pulling fuses, flipping switches, turning on and off the radio the drain quits and it returns to about a normal 0.2 amp pull. Then I am really stuck because I can't find whats wrong when its not pulling the 5 amps anymore. Anyone have any ideas, I have tried to turn things on and off, one at a time, and short of the headlights I can't even find anything the pulls nearly 5 amps. It is a problem that only happens about 1 out of 7 nights. It is sitting dead in my driveway now so at least I can start hunting for it again. Thanks for any advise. Brent
Old Oct 3, 2007 | 12:55 PM
alexs dad's Avatar
alexs dad
Default RE: Durango with a battery drain
Is your D a2004-2006? If so it is probablythe interior light capcitor that is on recall.
Old Oct 4, 2007 | 04:10 PM
magnumbp's Avatar
magnumbp
Nope, its a 2000. But thanks anyhow!
Old Oct 8, 2007 | 03:48 PM
spectre184's Avatar
spectre184
ORIGINAL: magnumbp
This fuse runs alot, my radio, .......
I'm not sure how stock stereos are is D's. but do they have an external amplifier? If so you may wnat to check to see if some how it's staying on all the time.
