Blinker Problem
Old Oct 1, 2007 | 03:09 PM
Mike2002's Avatar
Mike2002
Default Blinker Problem
I have a 200 Durnago that is having some blinker problems. The two blinkers work fine but they just blink really fast like there is a bulb burned out but neither of them are burned out. What could be causing this and what do I need to fix it. I'd like to do it myself cause i'm sure the dealer would charge an arm and a leg to fix it.
Old Oct 1, 2007 | 04:59 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: Blinker Problem
umm switch to synthetic blinker fluid??????
lol, but umm probably the timer that flips them on and off is bad, idk what its called, unless the bulbs in the dash are out, id start by checking all the wiring and bulbs to make sure they are good, cheapest things first
Old Oct 1, 2007 | 06:11 PM
Mike2002's Avatar
Mike2002
Actually last time I was at the dealer he put in special synthetic blinker fluid. It was only a few dollars more but we agreed that it was worth it for the longevity of the bulbs. I found the problem in this case though. There are two front blinker bulbs and one of them is burned out.
Old Oct 1, 2007 | 06:14 PM
shrpshtr325
THE ULTI-MOD
ok thats good, thanks for leting us know what was wrong, so many people dont then we are left scratching our heads
Old Oct 30, 2007 | 09:18 AM
JP2083's Avatar
JP2083
USE A SLOWER BLINKER FLUID
Old Oct 30, 2007 | 10:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
Have you try a new flasher combo.
