Water pump
Old Oct 16, 2007 | 10:19 AM
shdwghst's Avatar
shdwghst
Default Water pump
I have a 2003 durango 5.9L water pump went out yesterday. I replaced the pump theromstat, belt and tensioner. The truck did not run hot I noticed the leak while checking the oil. Now the truck is running hot any ideas ???
Old Oct 16, 2007 | 11:11 AM
durangeddurango's Avatar
durangeddurango
Default RE: Water pump
temp gauge reads? what degree t-stat did you install? did you purge all the air from the system? did you mix the coolant properly? stupid question but did you reinstall the belt the correctly?
Old Oct 16, 2007 | 01:50 PM
Kensai's Avatar
Kensai
Also, it may be possible the radiator may be clogged external/internally. run powerwash wand thru the radiator and if that does not solve it, it may be clogged internally and needs replacement.
Old Oct 17, 2007 | 05:13 AM
steve05ram360's Avatar
steve05ram360
you might still have an air bubble in the cooling system... turn the heater on full hot, remove the cap and rev the motor some to get the coolant flowing. you should be able to push out any air pockets. does your t-stat have an air bleed hole in the diaphram?
Old Oct 17, 2007 | 01:00 PM
shdwghst's Avatar
shdwghst
Thanks for the advice
I noticed yesterday that one on the hoses is leaking gonna replace that today and and Ill check about the air in the system
Old Oct 17, 2007 | 02:13 PM
shdwghst's Avatar
shdwghst
Hey that was it
I guess I had air in the system
Its not running hot
THANKS
Old Oct 20, 2007 | 06:38 AM
steve05ram360
awesome, thanks for giving us the feedback.
