HEATER HELP
Old Nov 4, 2007 | 01:20 PM
98 DURANGO's Avatar
98 DURANGO
Default HEATER HELP
I have a 98 Durango that intermittently will start blowing cold air out the passenger side floor no matter what osition the controls are set on. It used to only happen once in a while but is starting to happen more often. The evaporator core and heater core were replaced just before I bought it and was fine for a while. Any help would be appreciated.
Old Nov 5, 2007 | 12:16 PM
Kensai's Avatar
Kensai
Default RE: HEATER HELP
Do you even get heat at all from any of the other settings? If so, I would check your blend door. If you get no heater on any setting, check your heater hoses located under the hood. You should see two hoses side by side going into the firewall. Feel the hoses. if one is hot and one is cold, this means your heater core is clogged. If both hoses are hot, then it may be your blend door being stuck.
If you have a clogged core and you already replaced it recently, this is a sign that your cooling system itself needs a serious inspection. Check your radiator as well to make sure that is not about to be clogged up. You may need to do multiple flushing to really clean up your cooling system if need be.
Old Nov 6, 2007 | 07:12 PM
hydrashocker's Avatar
hydrashocker
Good call Kensia. Sounds like a blend door to me.
Old Nov 7, 2007 | 09:47 PM
Steeltown67's Avatar
Steeltown67
Iam having the same problem right now
an WE have determined it is the blend door stuck open
any ideas on fixing this problem
have been told to get skecmatics from dodge on the layout of the dash
don't really want to pull the dash
Steeltown
Old Nov 8, 2007 | 11:35 AM
durangeddurango's Avatar
durangeddurango
mine does the same replaced the t-stat, flushed it, blend door isoperating fine, only blows cooler at a idle, no air pockets present in the coolingsystem. water pump,radaitor were replaced less than 5k ago when I decided to play bumper cars at a stop light.......
Old Nov 8, 2007 | 12:24 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
I think there's a TSB on 2nd Dakota/1st gen Durango for pass side poor heater performance. It has something to do with the floor duct/vent positioning and there is an updated part. I'll try to dig up that bulletin.
Old Nov 8, 2007 | 05:39 PM
United1's Avatar
United1
Steeltown, you can get to the blend door cable connection on the HVAC box by pulling out the glove box. Once you remove it, you should be able to see the cable to the left. Check the cable to see if it is kinked.Worst case, you should be able to rotate the blend door by hand and maybe free it up.
Old Nov 8, 2007 | 06:05 PM
2000DirtyDurangoDD's Avatar
2000DirtyDurangoDD
My blend door opens and closes with the shifting of the tranny! What could cause that?
Old Nov 8, 2007 | 06:12 PM
United1's Avatar
United1
A blend door that is not attached to anything (broken cable) or more likely a vacuum leak.
