Tranny oil leaking
Old Nov 6, 2007 | 11:47 PM
Kagedmaniak's Avatar
Kagedmaniak
Default Tranny oil leaking
I have tranny oil leaking from around the tranny and the transfer case, its most likely due to the seals.
I was wondering how much it would cost to replace those seals, if anyone has done it before. (because taking it to a dealer or something seems the route I would go, since it may be hard to do all that without having a lift).
Thanks.
Old Nov 7, 2007 | 01:01 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: Tranny oil leaking
Which seal are we talking about? If it needs the one between t-case and tranny, about 2 hours labor + parts. IOW, a couple hundred bucks.
Old Nov 7, 2007 | 09:27 AM
n8ech's Avatar
n8ech
KMK:
As 66D says, there are several different seals that might be involved. Could be tranny front seal or rear. Also, T case has both frontand rear seal.
Although I to think that it SHOULD only be a couple hundred bucks at the most, my local dealer wanted $600 just to remove my part time t case and install my full time unit.
Best course is to get it diagnosed as best you can, then go from there. In any case, the part will likely be a very small part of the total repair cost.
Don
Old Nov 7, 2007 | 11:00 AM
kjun's Avatar
kjun
Which tranny (auto/manual). Also where you see the fluid does not mean thats where the leak is. The fluid could just be collecting there from air flow.
I only mention this because my 2000 Durango (auto trans) had quite a bit of fluid around the tranny and xfer case. My pan bolts were a little loose. Not wobbly lose obviously but no longer fully torqued. I cleaned up the area really good, retorqued the pan bolts and was good to go. No leaks anywhere else. It just looked that way from all of the fluid.
Just a thought.
