stalling
Old Nov 7, 2007 | 10:20 PM
dodge74's Avatar
dodge74
Default stalling
My durango drives forward normally, but when shifted into reverse it stalls and I can't keep it running. I checked all plugs, lines to make sure they were connected. I also don't have any check engine light come on am also not getting any codes to show up. Any help. Thanks
Old Nov 8, 2007 | 08:48 AM
hydrashocker's Avatar
hydrashocker
Default RE: stalling
Sounds like you are getting a bind in the trany. Tell us more about your truck. Year, Engine, Trans, ect.
Old Nov 8, 2007 | 10:36 PM
dodge74's Avatar
dodge74
The truck is a 2001 with the 5.9 motor. The transmission was replaced last week.
Old Nov 9, 2007 | 03:46 AM
Mean Green's Avatar
Mean Green
Well whoever did it needs to take care of their problem, unless it was you. [&:]
Old Nov 11, 2007 | 08:44 AM
dodge74's Avatar
dodge74
The person is taking care of it, I was just wondering what people thought it could be or had happen to them
Old Nov 28, 2007 | 11:03 AM
jpcelia's Avatar
jpcelia
I have a 1999 Durango with the exact same problem. I recently replaced the transmission with aremanufactured unit and thats when this problem started. I've called several Dodge Dealers, a Transmission Specialist and asked every Automobile Tech thatI knew, and no one had any concrete answer as to why this is happening. I calledthe remanufacturer of the transmission and they didn't have an answer, They sent me another transmission which did the same thing. I called them again and they have now sent me a third transmission. I am very leary to install this until I have a better answer as to the cause of this problem. If you get yours straightend out please let me know what the problem was. I'll do the same if I get mine figured out.
Old Nov 29, 2007 | 12:40 AM
noregrets's Avatar
noregrets
Did you guys replace the speed sensors when you replaced the transmissions? I've heard of something similiar happening to an Avenger transaxle when the speed sensor wasn't changed out with the transmission. In the cases I've heard of, the vehicles didn't give codes.
Ang
Old Dec 3, 2007 | 01:09 PM
jpcelia's Avatar
jpcelia
Yes - speed sensor was replaced with the transmission.
