2003 Durango Radio Removal and Workshop Manual
Old Nov 10, 2007 | 02:48 AM
archy's Avatar
archy
New Member
Default 2003 Durango Radio Removal and Workshop Manual
I live in Qatar in the Middle East and drive a 2003 Durango SLT+. I want to know where I can buy and download on line the full factory workshop/repair manual as used by the dealers. Also I need to remove the radio and need some guidance on how to do this without destroying the dash.
Thanks
Archy
Doha
Qatar [align=right][/align]
Old Nov 13, 2007 | 03:44 PM
SinCity R/T's Avatar
SinCity R/T
Default RE: 2003 Durango Radio Removal and Workshop Manual
FSM's can usually be found on E-Bay on a semi-regular basis.
There are two screws facing upward above the gauge cluster, then grab an edge on the big dash panel and pull outward - should pop right out. You will need to disconnect the wiring harness for the headlight switch, A/C control panel, 4x4 switch (if applicable), and airbag switch before you can get the panel completely removed. You may also need to shift the truck down into 1st gear for clearance (remember to set the e-brake!)
