I am having problems with my blinker on my 2000 Durango. It started acting up about 6 months ago. It would only work off and on. Now it has completely quit working. I assume there is a blinker module somewhere. Does anyone know where it is located? Any help is greatly appreciated. thanks
There is a relay that has probably gone bad. Same thing happened to me. I would put the blinker on, it would go off a couple times, and then stop. Put it one again, same thing....eventually it would only click once... Make sure you get the right relay from the stealership, there are two. I was lucky and mine was only $50, where the newer one was like $200.
Thanks guys! You have been a great help. I pulled out the relay and checked with the dodge dealer. $50.00 so by chance I checked the local packaged parts store. I found one for $14.97 and it works great! The part number was EP27 made by Tridon. Thanks again for the help.
