2000 r/t durango need help timing
Old Nov 19, 2007 | 01:33 PM
hary4925's Avatar
hary4925
Default 2000 r/t durango need help timing
I have a 2000 durango r/t which i just did a tune up to by replacing the distributer, cap, rotor button, spark plug wires, plugs. I am having a hard time finding the timing mark indicator. If anyone could please help that would be great. Thanks
Old Nov 19, 2007 | 10:12 PM
n8ech's Avatar
n8ech
Default RE: 2000 r/t durango need help timing
Harry:
It is possible that your D does not have one. On these newer cars, the timing is set by the computer, and is not user adjustable. Look for a small ring or hoop down beside the harmonic balancer. If you see one, this is where a magnetic sensor would be placed temporarily to check the timing.
Chances are, if you have not removed the distributor, you should not have to touch timing.
Don
Old Nov 20, 2007 | 10:29 AM
hary4925's Avatar
hary4925
Well i actually put a new distributor in but last night i found the timing mark it just auto adjusts itsself. Also does anyone know i heard that the R/T durangos have an advanced timingchipcan anyone tell me if thats true or not.
Old Nov 20, 2007 | 10:55 AM
n8ech's Avatar
n8ech
Harry:
Not 100% sure, but that would not surprise me. I am curious though as to what issues you were having to warrant replacement??
That is an unusual repair these days.
Don
Old Nov 21, 2007 | 01:18 AM
Mean Green's Avatar
Mean Green
Probably anMSD upgraden8ech
Old Nov 21, 2007 | 10:17 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
The 5.2 & 5.9l engines do require that you set base timing. Align the mark on the crank (on #1compression stroke) and then make sure the rotor is aligned with the mark on the distributor housing. The computer does everything else; no timing light is required.
