2001 Durango Electrical Problems
I have an 01 with 122,000 miles and have electrical problems. This problem has been going on for over a year but came to a head since I cannot pass my inspection. Here are the symptoms:radio will intermitedly turn off / on (radio turned on) and when that happens my blinkers do not work. This does not happen 100% of the time. However, I cannot engage 4wd as it does not appear that there is power to the switch.
What do you think?
Robbie Fuchs
What do you think?
Robbie Fuchs
I've noticed the same issue in my truck. I had the dealer look into it and they said that it was a sticky key cylinder in the ignition switch. All they did (or told me they did) was spray some lubricant in there to smooth things out. I still have issues with the from time to time. Sometimes I can get the radio/blinkers back if I wiggle the key while in the ignition/make sure it is all the way into the switch. This is really problematic when the truck is running, as on many occasions I've had to turn my truck off/back on at a red light or on the side of the road to get things cooperating again. It's just really a hassle, since we really need blinkers to NOT get pulled over.
I had initially suspected the clock spring as the culprit of this issue, as I noticed it would happen when the steering wheel would turn slightly. I did have the clock spring replaced not too long ago, but that was related to a whole different list of issues that have since been resolved. The radio/blinkers thing still persists from time to time.
I'm guessing that maybe the ignition switch/key seating in the switch is just not that great. Maybe replacing the unit will help? Try a different key? Hope something works...
