ABS Sensor Replacement
Old Nov 29, 2007 | 10:54 AM
20durango00's Avatar
20durango00
Default ABS Sensor Replacement
Need to changethe rear differential abs sensor on our 2000 Durango , anyone have r & r tips?? Does this sensor read off the ring gear?? Thanks.
Old Nov 29, 2007 | 06:52 PM
n8ech's Avatar
n8ech
Default RE: ABS Sensor Replacement
20D:
Yes, the sensor mounts into the top of the rear diff. IIRC, it is secured by one bolt. You might want to spray some wd-40 or other lubricantaroundit and let it soak a bit before removal. They can be tough to remove.
I would also try to clean off any crud that has accumulated aound it before removal so it does not fall into the diff.
Don
Do
