Puzzling Stalling and Idle Issues
Old Dec 10, 2007 | 09:05 PM
OMark's Avatar
OMark
Default Puzzling Stalling and Idle Issues
I have a 98 5.2L with 103k miles. No codes are being thrown. Running fine but developed a slight hesitation leaving a stop. Fresh tuneup and checked the vacuum lines with no change. Now when letting off the throttle to an moderate stop it stalls. Restart may or may not result in a idle rough then immediately stall again. A nice slow coast to a stop and it continues running fine. Hot or cold does not matter. I'm not in the habit of simply throwing parts at my cars. I'm thinking a sticky Idle Air Control Motor (IAC) but can't find a reasonable method of testing. Anyone have any ideas to test the IAC and/or other directions?
Old Dec 10, 2007 | 09:29 PM
tbasse01's Avatar
tbasse01
Default RE: Puzzling Stalling and Idle Issues
did you change the wires? or just plugs?
i would pop off the iac sensor and clean it up and just buy a new tps and throw it on too(will help with shifting and throttle response)
Old Dec 10, 2007 | 10:11 PM
daddy_bear_21's Avatar
daddy_bear_21
I had a similar issue, used some intake cleaner, sprayed it on the IAC and in the TB itself. Used a toothbrush to clean the TB seats, and it runs better than ever.
Old Dec 14, 2007 | 08:18 PM
daddy_bear_21
Hey, did you get it fixed? What did you find to be the problem? Hope everything is good
