Heated Seats HELP!!!!!!!
Old Dec 11, 2007 | 11:15 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default Heated Seats HELP!!!!!!!
I need some help, i know that i havnt been around alot in this forum but i was hoping that you guys could help me out.
this morning when i went to school my heated seats worked fine, but tonight on my way home i went to turn on the drivers seat(of course) and it did not heat up and when i look down at the switch to make sure it was on the light that should indicate that it is on high was flashing at me, flashing slowly like on for a sec off for 5 or more, any ideas on what to check, i looked in the manual and all it says is to have a certified technician look at it, useless, not going to pay somebody to fix it, but still want it fixed, any ideas would be great
Old Dec 12, 2007 | 08:11 PM
shrpshtr325
THE ULTI-MOD
Default RE: Heated Seats HELP!!!!!!!
come on guys i need to get this fixed, and btw i pulled the switch that is not the problem its been replaced and it didnt fix it
Old Dec 12, 2007 | 08:31 PM
MAGIC84's Avatar
MAGIC84
DID you check the FUSE?
Old Dec 12, 2007 | 09:03 PM
Heimer's Avatar
Heimer
Probably your heater element. You have an upper one for the back and a lower for the seat. They run about $100 a piece and you have to take apart the seat. I have the same problem with the driver and the passenger light is steady but no heat out of it either.
Old Dec 12, 2007 | 09:59 PM
shrpshtr325
THE ULTI-MOD
how hard is it to replace them, how does the seat come apart, and would this be a possible saturday project or should i plan to be w/o a ride for a weekend or more????
and yes i checked the fuse, its fine that was the first thing i checked, the switch was secound
