Temp in 2000 5.2 drango
Old Dec 18, 2007 | 11:12 AM
willie2124's Avatar
willie2124
Default Temp in 2000 5.2 drango
for the past 3 morings my d temp goes up to around 250 a few miles away from my house and then goes back down. Thats the only time it happens. Its at the same spot for the past 3 days. What is this from. If it is the Termostat is it hard to replace???
Old Dec 18, 2007 | 10:03 PM
gr8scott72's Avatar
gr8scott72
Default RE: Temp in 2000 5.2 drango
ORIGINAL: willie2124
Thermostat is cheap and easy to replace and that is the first thing I'd do to chase this problem down.
Old Dec 19, 2007 | 07:58 AM
n8ech's Avatar
n8ech
Willie:
I agree that the T stat sounds like a good place to start. While you are at , I would flush out the system really well, and put some good long life antireeze back in there. Finally, make sure that you purge all the air from the sytem before you button it up.
Sounds like theT stat is sticking shut for a bit.
Don
