Threw some codes
Old Dec 19, 2007 | 05:45 PM
motorider228's Avatar
motorider228
Default Threw some codes
My moms 2002 durango with the 4.7 threw some codes. P0734, Gear 4 ratio incorrect and P0733, Gear 3 ratio incorrect. What could these codes be? Is a tranny problem or what?
Old Dec 20, 2007 | 08:08 PM
ceedeelight's Avatar
ceedeelight
Default RE: Threw some codes
It does sound like a transmission problem to me. My 2002 4.7 gave code P0740 TCC and now I have to get a remanufactured transmission. [:@]
Old Dec 22, 2007 | 04:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
Your transmission is a 45rfe or 545rfe, remove the pan and inspect the valve body. You may have a broken accumlator plate. If it is broken there is a repair kit without replacing the valve body.
