replace with limited slip
Old Nov 30, 2004 | 02:09 PM
mikesram's Avatar
mikesram
Default replace with limited slip
I want to replace the rear end with a limited slip, Any good manuals out
there that will take you step by step? On a 2000 Durango.
Thanks
Old Nov 30, 2004 | 06:41 PM
moparturd's Avatar
moparturd
Default RE: replace with limited slip
If you use the same ring gear, you shouldn't have to worry about set-up when you swap the units.
