2000 Durango blinker problem! Help!!!
Old Jan 15, 2008 | 11:42 AM
SVT F15O's Avatar
SVT F15O
Default 2000 Durango blinker problem! Help!!!
Have a 2000 Durango here. No blinkers and no hazards. Changed the flasher(EP27), installed a bone yard multi function and checked all the bulbs. Fuses check out good. Anyone have any ideas>??? Getting frustrated. Thanks, Mat
Old Jan 15, 2008 | 12:52 PM
Duranged408's Avatar
Duranged408
Default RE: 2000 Durango blinker problem! Help!!!
Kinda a toughy as led through the previous of which are usually the culprit. Your next job is now locating the culprit in your electrical system (Cant rule out junk yard wiper/turn/hazard Unit-either) Its a pain sourcing the positive and negative feeds, but for a starter i'd suggest checking out the rear of the D. Towing harness is the last easy check before you've got to go digging.
Old Jan 15, 2008 | 03:19 PM
SVT F15O's Avatar
SVT F15O
Found the problem. Flasher relay was not getting key off power. Supplied key off power and all is good. It is a buddies truck. After looking at a diagram the second time I realized it needed power in 2 spots, not 1. Should have looked twice before he bought the multi function.
Old Jan 15, 2008 | 04:19 PM
Duranged408
Ooo so what was the exact fault then?
