Durango Issues
I have changed the following on my durango:
1. front crank seal
2. thermostat - twice
3. sway bar end links
4. ball joints
5. both rotors
6. rack and pinion unit
7. both rear speed sensors
8. timing cover gasket
I am waiting on my plenum gasket to go and for my transmission to mess up. My fog lights don't work and my brake and ABS lights are still on. All this and I only have 64000 miles on a 99 Durango.
I have to admit though...the engine runs good and hopfully it will for a long time.
1. front crank seal
4. ball joints
5. both rotors
ORIGINAL: doziersdodge
1. front crank seal
4. ball joints
5. both rotors
1. front crank seal
4. ball joints
5. both rotors
I haven't messed with my fog lights too much. I do know it is not a fuse or the bulbs. I plan on putting a volt meter on it to check everything. As far as the brakes go...I have tried everything. The pads and shoes are in good shape. The rotors needed changing due to being warped. I have completely bleed the system and checked all lines, master cylinder, brake cylinders and calipers. The only way that I have read to reset the computer is to disconnect the battery or go to a dodge dealer. Is that right? I have also seen a post on changing the ABS controller. I don't plan to spend $500 unless I have to on it. The brakes work fine...most of the time...they do tend to be touchy once and a while.
the light switch is probably bad. yea try the reset and see if they come back.
Disconnect NEG Battery Terminal
Turn the ignition key to the START position and hold for 15-20 seconds
Release key (OFF) and reconnect the battery
This sounds stupid but try it anyway dissconnect your battery for a min or two I have never really seen that problem with dodge but I have seen many chevs that had a problem with false readings that corrected themselves when you dissconected and reconnected the battery. worth a try anyway might just be a glitch instead of a problem.
Trending Topics
how do i reset computer on 2003 on dodge durango. i have disconnected neg cable for 5-10 minutes even overnight. truck starts ok but have no lights .what am i doing wrong. i have tried turning key on and off but still no luck,can anybody outthere help?????
sounds to me like a bigger problem than resetting your computer.
what do you mean by 'no lights'? no h eadlights? no interior lights? no dash lights? no brake lights? all of the above? have you checked the aplicable fuses for the affected systems? checked for relays that could be bad if its the headlights/foglights that are out?
