98 5.9 Durango rough idle
Old Jan 25, 2008 | 04:41 PM
cudadrt's Avatar
cudadrt
Default 98 5.9 Durango rough idle
I've got a 98 durango 5.9 with 125k miles and it started last week gettin g a rough idle when I stop. I checked the error code and got a IAC malfunction code and a TCC malfunction code. I reset the codes and replaced the IAC and TPS but still have the same problem. Is there a problem with the tranny by chance? It's shifting and running fine but when I come to a stop it seems fine for a minute then it starts to rough idle and almost die. Once I take off it runs fine until I come to a stop again. Any info is greatly appreciated.
Old Jan 25, 2008 | 07:21 PM
n8ech's Avatar
n8ech
Default RE: 98 5.9 Durango rough idle
Cuda:
Sounds like your TCC (torque convertor clutch) is not unlocking at idle, which would cause what you are having. Kinda like driving a stick shift and not depressing the clutch when you come tostop.
Not being a tranny man, someone else will have to guide you from here.
Good luck Don
Old Jan 26, 2008 | 07:14 AM
cudadrt's Avatar
cudadrt
Thanks for the posting...greatly appreciated...for the first time today it's started working fine again but if anyone has any answers on to what to do about the converter please let me know...is there a sensor that needs to be replaced or the converter itself? Any and all help is greatly appreciated. Thanks!
Dwayne
