Wipers quit while running
Old Feb 1, 2008 | 05:00 PM
rchiefari's Avatar
rchiefari
Default Wipers quit while running
My wipers quit (while running)as well as the fluid pump. I checked the fuse block under the hood ...all good. Can't find any other fuse block. I would suspect the motor, but figured since the fluid won't pump either - it's electrical. Anyone know where they hid another fuse panel?
Old Feb 2, 2008 | 03:55 PM
rchiefari's Avatar
rchiefari
Default RE: Wipers quit while running
Found it - left hand drivers side dash -- stares you in the face as you open the door....how'd I missed that!?
-Bob
2000 Durango SLT 4X4
Old Feb 8, 2008 | 04:28 AM
restlesswynd's Avatar
restlesswynd
I had the same problem, but check out this twist.....
Mine went out while in use also, so I turned them off and replaced the fuse. When I installed a new fuse it blew immediately. On a whim, I turned the wipers on before putting in the 4th fuse. Voila!!!
My question is: Why would it blow when the wipers are off and no blow when they are on?????
Thanks
