th d backfired and died need help
Old Feb 6, 2008 | 10:04 PM
bigbaddurango's Avatar
bigbaddurango
Default th d backfired and died need help
I was going to my girls and was runing about 40 mph and a big boom back fired and died and that was it wouldnt start. We towed it home i started checking the basics no spark so checked the power to the coil doesnt seem to have a + signal going to it i cant find a wiring diagram that gives any detail other then the wire goes to the comp any help would be great its getting fuel i thought the timing chain had broke the d has 159,000 on it dont no if it had been replaced or not but the rotor still turns if it jumped time it should still have spark right
Old Feb 6, 2008 | 10:29 PM
n8ech's Avatar
n8ech
Default RE: th d backfired and died need help
BBD:
Observe your tach when you try to start the engine. If it does not move or bounce a bit, then you may have lost your CPS (crank position sensor)
Try the key on key off procedure, and see if you have any trouble codes stored.
What year is your D and what engine??
Don
Old Feb 6, 2008 | 10:54 PM
bigbaddurango
Its a 2000 and a 360 engine light has been on and off for long time took it and tested it it said misfire bank 3 or something but then it goes away i did a full tune up on it awhile back didnt help i will go out right now and try it and let you no how do you get the codes?
Old Feb 6, 2008 | 11:15 PM
bigbaddurango
not much movement on the tack it goes up to te first bar real slow
Old Feb 7, 2008 | 09:30 PM
bigbaddurango
bump bump
Old Feb 8, 2008 | 07:10 PM
n8ech's Avatar
n8ech
BBD:
From the sound of it, I think your CPS is ok. Process for getting the codes is:
Key on, off, on, off, on..... Any stored codes should come up in your odometer window. If it says pdone, there are none stored.
I would also take a hard look at the ign coil. Seem like alot of the 5.9s have had them go belly up lately.
Don
