5.9 towing 4k lbs.
Old Feb 8, 2008 | 04:12 AM
restlesswynd's Avatar
restlesswynd
Default 5.9 towing 4k lbs.
Hey there,
I've got a 99 D 5.9L, 5sp TCase, uncertain of gear ratio. I tow my 4k lb Travel Trailer and was wondering how others felt their D pulled similar or heavier loads? I feel like I have the power to muscle up the hills in Northern Cali but feel like I'm really putting a beating on my engine. I try not to rev past 3k rpms. How high do you run your RPM's?
Does anyone know what the power curve on the 5.9's is? Where do I generate the most torque and horsepower?
Thanks!
Old Feb 8, 2008 | 03:05 PM
Kensai's Avatar
Kensai
Default RE: 5.9 towing 4k lbs.
The 5.9 engine reaches it peak hp/torque range at 3k rpms. At least that is the sweet spot for me and that is where I feel the power.
also, your Tcase is a 5 speed??? It should only be a 4 speed. 5 Speed autos are only available starting year 2000 models with the 4.7 engine package.
Old Feb 10, 2008 | 01:33 AM
restlesswynd
Thanks for the info
Sorry, you're right, 4spd. 2wd, 4pt, 4hi, n, 4lo
Old Feb 11, 2008 | 12:59 PM
gr8scott72's Avatar
gr8scott72
ORIGINAL: restlesswynd
Thanks for the info
Those aren't considered speeds. Gear ranges maybe.
Also, what rear diff ratio do you have. Should be sticker in glove box to tell you that.
Old Feb 12, 2008 | 03:02 AM
restlesswynd
Yah, I meant to edit my previous mssg re: 4sp vs. the transfer case options.
There is no info at all in the glove box.
How else can I find out what gears are in it?
