Brake Controller HELP!
Old Feb 9, 2008 | 02:07 PM
big_b_8888's Avatar
big_b_8888
Default Brake Controller HELP!
I have a 2001 Durango WITHOUT the factory tow package. I am about to install a Reese hitch, wiring harness, and brake controller....
Where can I hook up the Brake controller "brake signal wire" Or whatever it is called... I look above the brake pedal and there is a plug that has 6 or 7 wires... is it one of those? Anyone know what one ? Or possibly an easier way to install it ?
Thanks
Old Feb 10, 2008 | 11:02 PM
partsjockey's Avatar
partsjockey
Default RE: Brake Controller HELP!
It should be the White/Tan wire at the brake light switch. Easy to get with a t tap.
Old Feb 11, 2008 | 07:07 AM
Duranged408's Avatar
Duranged408
If you have not purchased the equipment yet i would recommend getting a harness adapter so you wont have to deal with tapping etc. Thats me though, heres a quick example of what i mean. http://www.truckspring.com/productin...61&affid=1
Old Feb 11, 2008 | 07:58 AM
big_b_8888's Avatar
big_b_8888
White/Tan wire... Got it ! That is all I needed to know ... I guess that makes sense since the brake light wires behind the tail lights are also white/tan.
Thank you
Old Feb 11, 2008 | 12:38 PM
gr8scott72's Avatar
gr8scott72
ORIGINAL: big_b_8888
Thank you
Simple volt meter test will tell you which one it is also. Just find the one that changes when you press the brake pedal.
ORIGINAL: Duranged408
I never found one for the 00 Durango that didn't have a stock tow package on it.
