upper radiator hose
Old Feb 9, 2008 | 03:10 PM
mrwilliwizard's Avatar
mrwilliwizard
Default upper radiator hose
i have a big leak in my upper radiator hose and im going to just replace it along with the thermostat . i was wondering is the thermostat located where the upper hose connects to the engine or the lower hose?
thanks
2001 4x4 4.7L dodge durango
Old Feb 10, 2008 | 01:35 PM
hydrashocker's Avatar
hydrashocker
Default RE: upper radiator hose
The upper. Where the upper hose connects to the engine.
Make sure the new T-stat gets but into the engine the same way it came out. Spring down.
Also, I always test my new T-stat before installing it in hot water on the stove with a thermometer and make sure it opens at the right temp. I have had bad brand new T-stats before that are no good.
Old Feb 10, 2008 | 07:26 PM
n8ech's Avatar
n8ech
Wizard;
Since you have the 4.7 liter, your T stat is at the engine end of the bottom hose. There are two nuts that hold on a plastic housing to the engine. Be careful though as those two bolts are knownto break easily. I would suggest soaking them good with some PB Blaster or WD 40 and let it sit overnight before you tackle the job.
Don
