98 durango and duel exhaust
Old Feb 12, 2008 | 12:24 AM
OddBall85's Avatar
OddBall85
Default 98 durango and duel exhaust
Ok I bought a 98 durango a little while ago and I want to know if anyone knows of a duel exhaust that will work for it before I just go buy a flowmaster 50 series or something like that or build a duel exhaust of my own (would rather buy one then build one)
Old Feb 12, 2008 | 08:26 AM
Duranged408's Avatar
Duranged408
Default RE: 98 durango and duel exhaust
There's plenty of flowmaster Single in Dual out kits out there (If thats what your talking about and not true duals), just got to look around because most are 40 series such as mine. I chose to remove my spare tire though because even if the stock tire fitted its to small. Mine was purchased as a kit such as this http://www.macautoparts.net/ProductInfo.aspx?id=516829, but for extra protection i cleaned up the pipes, then gave em a spray down with high temp. The kit i recieved came with most if not all of the mounting hardware.
Old Feb 12, 2008 | 10:47 AM
gr8scott72's Avatar
gr8scott72
ORIGINAL: OddBall85
You can probably get just about any muffler shop to make you a single in, dual out system that's routed around the spare. I don't really see the point unless you are making it true dual exhaust.
p.s. It's dual, not duel.
Old Feb 12, 2008 | 02:44 PM
spsustu's Avatar
spsustu
I was just wondering how that 40 series sounded. Im sure it's throaty but is it obnoxious?
Old Feb 12, 2008 | 06:40 PM
Duranged408
Iv'e got a little drone on the inside, not really too bad on the outside unless im on it hard. No crackle at all on decel unless shifted into a lower gear, but otherwise sounding great. Also i now have afactory tester spray for heat and sound applied so its even more quiet, somewhat dissapointing to me now lmao.
Old Feb 12, 2008 | 07:27 PM
Kensai's Avatar
Kensai
If you are looking for a bolt on tru dual setup, go to GSMotorsports website. Bolt on kit bolts on starting from your exhaust manifold all the way to the back. Kit includes crossover and dual mufflers. Cats are additional cost.
http://www.gsmotorsports.com/Merchan...Code=GSMDUREXH
Old Feb 15, 2008 | 10:52 AM
durangoguy16's Avatar
durangoguy16
I have a 1 in 2 out muffler on mine. the pipes go out the muffler and around the spare nd come out the rear corners almost a little on the side.. good way to put it especialy because i have a full size matching spare to the rim/tire i have on the truck. only problem is that i think it was a custom built exause befor i got it and they put pressure on it unstead of bending it enough to just hang and its creating cracks in the hangers and the muffler ect...
Old Feb 15, 2008 | 11:06 AM
OneBadKota's Avatar
OneBadKota
I would recommend just doing a 14inch oval magnaflow on stock exhaust. Unless you think duals look cool, other wise I'd only do duals if they are true. Everyone asks me if I have dual exhaust.
Here's a clip of it on my 4.7. I only did a slight rev on it.
