No Heat
Old Nov 14, 2008 | 10:16 PM
papo's Avatar
papo
iv read about the 180 t stat but there is a problem with that to your durango doesnot go into closed loop mode until 195 d ,does youre ac work at all it is ecu control when you reach 210 ecu shut it off check youre coolant system for preasure you will see you have none if its not preasure then youre heater core is stuffed up, what temp does youre truck run.
