Transmission Temp Sensor Location
Old Feb 16, 2008 | 02:38 PM
Orezona's Avatar
Orezona
Default Transmission Temp Sensor Location
A search only resulted in a few unrelated threads.
I'm looking to add a good aftermarket trans temp gauge to the wife's D. Do I need to get a pan w/ port for the sensor or is there a port available on the trans already.
Thanks in advance.
Old Feb 18, 2008 | 03:12 PM
hydrashocker's Avatar
hydrashocker
Default RE: Transmission Temp Sensor Location
I know that there is a temp gage idiot light sensor, but I think it is in the input or output sensor. Output most likely.
You can get after market pans with threaded input sensors for about $150 at http://www.summitracing.com/
You can get deep pans. Or you can also drill out your pan and install a input sensor.
Old Feb 20, 2008 | 04:31 PM
Orezona's Avatar
Orezona
Thanks for the reply. I hadn't been on here in a few days.
Old Feb 20, 2008 | 05:01 PM
Orezona's Avatar
Orezona
Also, is my trans the 45RFE?
Old Feb 21, 2008 | 06:35 PM
hydrashocker
You've got the 45RFE trans
